Joining to an existing excel spreadsheet
  • October 23, 2015
  • 288 views
I have an existing excel spreadsheet that I want to update with values calculated in an FME workbench.
The existing excel spreadsheet contains a column with a unique ID that I want to join on from the data in the FME workbench.
I know how to join within a workbench using FeatureMerger or Joiner, but trying to join on a writer seems a bit more difficult.  Any ideas?
Thanks,
pratap
Forum|alt.badge.img+11
  • October 24, 2015
I dont understand what do you mean by "Join on writer"... I think, you want to fill attributes based on the unique ID wise.
Is there any issue, if you writer in new file along with unique ID and use that file?
  • October 26, 2015
Hi Pratap, thank you for your response.
Yes I worded it quite badly, what I want to do is add a value in the same row as the unique ID in the existing spreadsheet.  I actually worked out that I could do this by exposing the "xlsx_row_id" in the "Format Attributes" of the reader and then in the writer "Format Parameters" I selected the "xlsx_row_id" as the "Row ID Attribute".
This then ensured that the values were populated in the appropriate rows.
  • February 2, 2017
Glad to hear that you worked it out. This post has some other useful excel writing tips similar to what you are describing:
https://knowledge.safe.com/articles/29982/working-with-the-excel-writer.html
