Join tables using FME
  • Jan 27, 2020 3:41 PM UTC
  • 73 views
I have a line .kml which is needed to converted to shape. And I need to make a relation between "Folder" and "Placemark". I have a common field (kml_id in "Folder" and kml_parent in Placemark). How can I join them ?
  • Jan 27, 2020 3:44 PM UTC
The easiest is perhaps to use the FeatureJoiner.
Alternatively there is also the FeatureMerger and the InlineQuerier.
caracadrian
Forum|alt.badge.img+23
  • Jan 27, 2020 4:37 PM UTC
You can always insert the .kml as Single Merged Feature Type. That usually does the work for me.
  • Jan 27, 2020 8:26 PM UTC
Thx a lot! That one works for me.
