Iterate through a table based on a list of values
  • Aug 17, 2022 3:33 PM UTC
  • 223 views
I would like to iterate through a table based on a list of values. This is the process I would like to automate:
Filter the table on a value then add an attribute and BulkAttributeRenamer. I have 20 values so I'd like to be able loop through the table for each value rather than have a set of transformers for every value.
Best answer by ebygomm
It's not 100% clear what you're trying to do. Perhaps this sort of workflow is what you're aiming for?
imageThe only change if you have 20 values would be additional attributes to expose in the AttributeExposer
@vcarr2005​ Can you attach a small example dataset. It looks like you should be able to do this in series
  • Aug 18, 2022 7:03 AM UTC
Thank you, Mark. I've attached a file
Forum|alt.badge.img+54
  • Aug 18, 2022 9:09 AM UTC
  • Aug 19, 2022 11:17 AM UTC
Thank you @ebygomm! This is exactly what I needed. I had created something similar but I didn't have the Aggregator configured correctly.
