Iterate independently over files (and don't merge features)
  • Oct 26, 2022 3:59 PM UTC
  • 109 views
Hello,
I use a Reader to list files inside a directory, connected to a FeatureReader to read the features.
Currently, all features of all files are merged. ie. if I have 100 files with 100 features each, the output of FeatureReader will be 10.000 features.
Is it possible to iterate incrementally over each file, ie. to execute a pipeline independently for each input file, so that the FeatureReader will be executed 100 times with 100 output features ?
Thanks!
Best answer by dustin
If you put the FeatureReader and everything downstream into a separate workspace, you could feed your 'files' reader into a WorkspaceRunner. For each file that enters the WorkspaceRunner, it would process that independently in the 2nd workspace.
DanAtSafe
Forum|alt.badge.img+23
  • Oct 26, 2022 4:06 PM UTC
@0x974​ The FeatureReader is triggered when a feature enters it. In your case it is "executed" 100 times. After the FeatureReader you'll need to group by the fme_basename or another attribute value that is unique for each input file. Those 10,0000 features should come out of the FeatureReader in the same order that the 100 files went in.
dustin
Forum|alt.badge.img+36
  • Oct 26, 2022 4:47 PM UTC
  • Oct 31, 2022 6:52 AM UTC
Yes, I did this, that worked like a charm. Thanks!
