Issues using geometry as a parameter for WorkspaceRunner?
  • Sep 21, 2023 9:46 PM UTC
  • 137 views
Hello!
I have a workspace selecting a feature then passing its geometry into a different workspace for analysis:
imageHowever, I receive these messages and the second workspace doesn't run:
WorkspaceRunner_CleanerUpperOfBatchesInitiator (CreationFactory): Created 1 features
WorkspaceRunner_CleanerUpperOfBatchesDoWeNeedToDoIt (TestFactory): Tested 1 input feature(s) -- 0 feature(s) passed and 1 feature(s) failed
WorkspaceRunner_CleanerUpperOfBatchesRunner (TestFactory): Tested 0 input feature(s) -- 0 feature(s) passed and 0 feature(s) failed
Here is the Geometry Extractor:
Here is the WorkspaceRunner:
Troubleshooting:
When I removed the geometry as a parameter for the second workspace, the WorkspaceRunner succeeded. If I copy the GeoJSON text directly into the analysis boundary box, WorkspaceRunner succeeds as well.
I would love some guidance on this! Thank you!
nielsgerrits
Forum|alt.badge.img+67
I can reproduce your issue. Not exactly sure what causes this but I suspect the GeoJSON is interfering with workbench using JSON to start the child workspace.
You can use GeoJSON, but you have to URL Encode it using a TextEncoder in the parent workspace. Then put a TextDecoder before the GeometryReplacer in the child workspace.
itsmatt
Forum|alt.badge.img+48
  • Sep 22, 2023 12:11 PM UTC
Yeah, I found a similar issue in the FME Server web UI when picking GeoJSON geometry - The issue was certain characters we not getting escaped. Great idea to use the TextEncoder here.
