Issues reading coordinate system on FME 2023
  • Dec 11, 2023 6:36 AM UTC
  • 375 views
jp12212
Forum|alt.badge.img+4
Hi All,
I'm running a workbench that worked fine in my last FME ('22 now running '23) on the same files.
These are the errors I'm getting below - I'm thinking this could be something with the new FME and coordinate systems?
Any thoughts are appreciated.
Feature Caching is ON
The workspace may run slower because features are being output and recorded on all output ports regardless of whether or not there is a connection.
AutoCAD Reader: Failed to retrieve or apply texture for mesh entity. Texture must be file based with a valid path. The texture information will be skipped
... Last line repeated 9 times ...
Further instances of this message will be suppressed
AutoCAD Reader: Failed to locate or read world file. Geometric attributes will not be transformed
AutoCAD Reader: Found a coordinate system named `MGA-55' in file `xxxxxx.dwg', which is deprecated in FME. Continuing to read with this coordinate system data
Error running translation.
saraatsafe
Forum|alt.badge.img+13
  • Dec 13, 2023 10:01 PM UTC
Hi @jp12212​ , I believe you may need to add a Reprojector to your workspace. It looks to me like FME supports the MGA-55 coordinate system but perhaps it isn't named in a way that FME expects-- in our Coordinate System Gallery, I see MGA94-55 and MGA2020-55_FME, which might be what you're going for. You can take a look at this Gallery by adding a Reprojector, going into the Parameters, clicking on the dropdown arrow next to the Destination Coordinate System field, and clicking on "More Coordinate Systems...". Please feel free to give this a try and let me know if it helps with your issue!
