Issue with the JSONFragmenter in FME Server 2017.1?
  • Oct 2, 2017 5:54 AM UTC
  • 136 views
andybates
Hi guys,
I've got an issue with the JSONFragmenter in FME Server 2017.1 (Build 17539 - win64). Well, I think I have... maybe I'm missing something!
Any non-JSON input seems to cause the workspace to finish with an error rather than carry on :
"A fatal error has occurred. Check the logfile above for details". But there's no further clues in the log :
Loaded module 'JSONQueryFactory' from file 'C:\Program Files\FMEServer\Server\fme\plugins/JSONQueryFactory.dll'
FME API version of module 'JSONQueryFactory' matches current internal version (3.8 20170315).
Emptying factory pipeline.
The same workspace runs fine in FME Desktop where any non-JSON inputs come out of the "Rejected" port and the workspace happily carries on (I've got "Rejected Feature Handling" set to "Continue Translation" in FME Desktop).
I've added in a Tester before the JSONFragmenter in my workspace for now, but I'm curious as to why this is behaving differently in FME Server.
Any ideas?
Here's a screenshot of my simple test workspace which I uploaded into FME Server (job submitter service) :
Cheers
Batesy
Best answer by richardatsafe
Hi @batesy,
Thanks for noting this. We are working making sure were consistent with our rejected feature handling in Server. I can reproduce the issue and we have a PR to make the changes. As a workaround if you want the workspace to continue running on FME Server you can add any transformer eg. logger to the rejected port and it will keep processing.
richardatsafe
Forum|alt.badge.img+11
  • Oct 2, 2017 6:01 PM UTC
Hi @batesy,
andybates
  • Oct 3, 2017 1:25 AM UTC
Hi @batesy,
Ok cool, thanks for the reply @RichardAtSafe. The Logger does the trick for now, thanks for the tip.
mmccart
Forum|alt.badge.img+33
  • Nov 1, 2017 12:01 PM UTC
Hi @batesy,
I ran into the same issue in 2017.1.1 Server and the 'Logger' trick worked for me. Thanks!
deanatsafe
  • Jan 6, 2018 1:01 AM UTC
Thanks again for the feedback. There appears to be a problem with rejected feature handling for JSONFragmenter in both FME 2017 and FME 2018. I've reproduced the problem here and have filed a bug report. This only seems to come up when the workspace is run 'headless' - that is with WorkspaceRunner or on FME Server. My guess is that the rejected port caching for inspection is acting like a logger when run interactively on Workbench. This does seem to be related to JSON transformers as a similar configuration using Bufferer rejected features did not fail, whereas JSONExtractor does fail.
In the meantime for a workaround you can add any transformer such as a Logger to the rejected port and the workspace will complete. Or use a JSONValidator to validate your json document before doing any of your parsing. You could then eliminate any features with invalid json before they get to the JSONFragmenters. Note that a similar problem was fixed recently in FME 2018 for JSONValidator.
We will definitely prioritize testing and fixing this for these other JSON transformers, and post a note here once a fix is available.
