Issue using CSMapReprojector to transform to OSGB-GPS-2015-OSTN15
  • Dec 11, 2020 11:10 AM UTC
  • 0 replies
  • 43 views
ghareth
I've found a problem reprojecting 3D data using the CSMapReprojector transformer in 2020.1 running on MacOS Mojave.
Essentially, the Transformer behaves badly when the Destination Coordinate System is set to OSGB-GPS-2015-OSTN15. The problem is demonstrated in the attached workspace.
Thanks
