is there any way to set the coordinate system of tiff?
  • Mar 4, 2024 8:16 AM UTC
  • 5 replies
  • 470 views
totree30
Forum|alt.badge.img+3
Hello! I just got ortho images from Realworks, but I got images without coordinate system and some information in txt format. Is there any way to put this txt file as a coordinate system in FME?
At last, I would like to get EPSG : 3857 geo referenced ortho images.
itsmatt
Forum|alt.badge.img+48
  • Mar 4, 2024 8:21 AM UTC
You can set/define the input coordinate system in the reader.
By default FME will try and read it from the input, but if none is detected then it will fall back to unknonw an you will need to define it.
If you don’t know the coordinate system of the data then you could try a few different ones and check that the data are in the right place using FME and a background map. But the fastest/best way might be to contact the data provider and ask for the coordinate system.
For reprojecting you can use either the CSMapReprojector or the Reprojector transformer.
nielsgerrits
Forum|alt.badge.img+67
You can put rasters on coordinates using the RasterGeoreferencer, based on the extents.
totree30
  • Mar 4, 2024 8:25 AM UTC
Thank you for reply! The problem is, it doesn’t have a coordinate system,
I mean, my image has x,y,z value as you can see on the txt file, but in fme data inspector, it recognized the image as only x,y (starting from 0,0), and I think it is a default value.
totree30
  • Mar 4, 2024 8:26 AM UTC
because my image is a texture of  buildings
hkingsbury
Forum|alt.badge.img+73
  • Mar 6, 2024 6:57 PM UTC
It’s possible those coordinates are a local coordinate system specific to the project that imagery was extract from in RealWorks (assumption, never used RealWorks - or heard of it before now)
https://pro.arcgis.com/en/pro-app/3.1/help/mapping/properties/coordinate-systems-and-projections.htm
The origin (0,0) of these coordinates will be defined at the project level. You’ll need to get in touch with whoever setup the project and find where (0,0) is in real world coordinates. You may need to reproject this coordinate into a meters based system (say if its wgs84-ll)
You can then use the offsetter to offset from that real world coordinate using your xy values then the coordinate system setter to set the rasters to the real world coordinate system. If thats not in 3857 then you will need to reproject the rasters as mentioned above
