is there any way i can calculate distance between points of gas station on highways on each side of road
  • Dec 4, 2019 7:36 AM UTC
  • 79 views
mehar
Forum|alt.badge.img+3
i have points for each gas stations on both side of highways and shape file of highways road network..
i want to caclulate the distance between gas stations on each side .. and side of gas station
becchr
Forum|alt.badge.img+35
  • Dec 4, 2019 8:27 AM UTC
hi @mehar if I understand your question well, the LeftRightSpatialCalculator is what you're looking for?
That can split your gas station dataset to a 'left' one and a 'right' one. Afterwards the NeighborFinder can get you the distances for each station of one side
Hope this gets you to the right direction?
mehar
  • Dec 4, 2019 11:44 AM UTC
thanks @becchr , i tried leftrightcalculator but it didnot give me the accurate result,, also the distance i got from neighborfinder is in unknown units..
becchr
  • Dec 4, 2019 4:54 PM UTC
hi @mehar, for the first problem, you use one of the road sides as input? and the segments are all directed in the same direction?
for the second problem: seems you use unprojected data (geographical coordinates), there's a GeographicNeighborFinder on the hub or you can reproject your data first to a local coordinatesystem
