is there any trasformer to store lyrx symobologies to Cad format
  • Sep 3, 2021 2:15 PM UTC
  • 162 views
swethabhupathi
Forum|alt.badge.img+5
am using Arcgis Pro and i have few feature classes with different symbologies for them. i want to see those data in cad with same symbologies.
i saved the feature class to layer file and added in to fme . when i am writing it in to dwg i am not getting any symbology.
Can any one help on this
Forum|alt.badge.img+63
I'm not sure FME actually reads the symbology from the lyr file. If you view it in FME Data Inspector, do you see the symbology you want? If not then you're probably out of luck and need to recreate the symbology using DWGStyler's
