Is there any solution to remove fields with emply attribues in excel
  • Jul 10, 2019 1:37 PM UTC
  • 6 replies
  • 174 views
mehar
Forum|alt.badge.img+3
Paid_Services11.xlsx( my problem is i have an excel which is about the survey of stations, in some stations there are 3 restaurents and some had 4 restaurents and some only 1, but in survey form we gave questions for maximum 10 restaurents in mdc giscloud.when we export the data in excel it shows all 10 restaurents fields even if they filled for less . i want to remove the fields with no attributes..
sample file is attached .. thanks
Best answer by jovitaatsafe
Hi @mehar,
I was able to get a successful result in removing attributes/fields with empty values using @takashi's answer where he has also attached a workspace template. Here are the changes that you need to make to his provided workspace to get the result you are looking for:
  1. Replace the reader with an Excel reader pointed at your file
  2. Open the Aggregator and replace 'Attributes to Concatenate' by deselecting all and select all again. Make sure not to select the old attributes highlighted in red.
  3. Next, open the PythonCaller and where it's highlighted red under 'Attributes to Hide', deselect the existing ones and select all on your attributes.
  4. Go into the FeatureReader and re-read the excel file you provided. Remember to change the Format and the file path
  5. Replace the shapefile writer with an Excel writer (if excel is your output). Remember to set the Sheet Definition to 'Dynamic (Advanced)'. I also like to set the Drop Existing sheets and Truncate to yes in case you run the workspace multiple times for testing
  6. Open up the writer feature parameters after you've added the writer. In Schema Sources, set it to 'Schema from Schema Feature'
6-schema-sources
Press OK and set the 'Schema Definition Name' to fme_feature_type.
It should look something like this:
7-writer-params
Note that in the output the X and Y column appear to be reordered last in the Inspector (not sure why), but the actual excel output looks ordered correctly.
While the workspace is from some time ago, I was able to get my result without upgrading any of the workspace, I just opened it up in FME 2019.1. Hope that works for you as well (and thank you Takashi for a wonderful solution)!
jovitaatsafe
Forum|alt.badge.img+11
Hi @mehar,
It looks like there are some great ideas for removing empty attributes from these two previous Q&A;s.
Xiaomeng's answer suggests using the AttributeExploder and and filtering out only values that are not exmpty (ex. Tester to see if an attribute value exists).
And takashi's answers in this question offers a few options including the NullAttributeMapper, and a script for the PythonCaller. In another Q&A taskashi also has a workspace template for a different solution.
mehar
  • Jul 11, 2019 5:22 AM UTC
@jovitaatsafe thanks for the reply but attribute exploder and nullattributemapper didnot work with me,
i want to delete fields with empty attributes .. i hope if you check the attached excel..
thanks
gio
Forum|alt.badge.img+15
  • Jul 11, 2019 11:01 AM UTC
@mehar
Like @jovitaatsafe said, this has been asked and answered many a time.
I assume you mean empty row and not considering the first five columns.
Here is a tiny script (which is using attribute exploder)
Excel count non empty cols per row forumMehar.fmwt
added image
Greets.
mehar
  • Jul 11, 2019 12:20 PM UTC
@mehar
added image
Greets.
hi @gio
thanks for script but the columns with no attributes are not deleted i mean i need to delete the columns which have no attributes according to every row there is information about the station
by running the script it didnot deleted the columns with no attributes
jovitaatsafe
  • Jul 12, 2019 12:53 AM UTC
Hi @mehar,
6-schema-sources
7-writer-params
mehar
  • Jul 14, 2019 6:57 AM UTC
Hi @mehar,
6-schema-sources
7-writer-params
hi @jovitaatsafe
hope you are well and good in health..
thanks for the solution and guidelines
it work for me this time ..
thankyou very much for your precious time
