Is there any other way to write data into the ArcGIS portal besides the ArcGIS Online Connector?
  • Sep 26, 2023 4:50 PM UTC
  • 142 views
fme_can_do_it
Forum|alt.badge.img+13
I am working on an Excel spreadsheet that contains employee information from various markets. My aim is to extract this data and import it into the ArcGIS portal. However, the only transformer I know of that can accomplish this task is the ArcGIS Online Connector. The problem I am facing is that it requires a file to be uploaded, which is not very useful in my workspace. I do not want to save my output file; instead, I want to write it directly to the portal. I would greatly appreciate any feedback. Thank you!
Best answer by rickklopping
@fme_can_do_it​, I understand you want to read data and then write it to ArcGIS Online. If you choose not to upload a file, you can opt to use the default 'FeatureWriter'. Below you'll find an example.
I have created a spreadsheet in Excel for you.
Screenshot 2023-09-26 200007
I read the data using a FeatureReader, perform a dummy transformation, and then write everything using the FeatureWriter.02. Process in FMEIn the settings of the FeatureWriter, I select 'Esri ArcGIS Online (AGOL) Feature Service' as the format.
03. Feature writer settings
After running my workspace, I can see the data in ArcGIS Online.
04. Data in AGOL
This means I was able to read, transform, and publish the data from the Excel file without having to write it temporarily in between. Does this answer your question?
rickklopping
  • Sep 26, 2023 6:10 PM UTC
04. Data in AGOL
havmoejbv
Forum|alt.badge.img+16
  • Sep 28, 2023 10:27 AM UTC
If you are working with ArcGIS Portal, I'd suggest having a look at the Esri ArcGIS Portal Feature Service Reader/Writer. I have only used it to read/update existing services, but based on the documentation you should be able to create service as well (with a few limitations).
fme_can_do_it
  • Oct 2, 2023 6:18 PM UTC
04. Data in AGOL
thanks @ernie​ ! That solves my problem!
rickklopping
That's good to hear. Best of luck with your workspace, and feel free to reach out to me for any questions or feedback.
