Is there an easy way way to mange the configuration files path? We are migrating our network shared drives where resides these configuration and we want to avoid to re-install FME Server.
  • Dec 15, 2017 3:39 PM UTC
  • 77 views
Regards.
Etienne
  • Dec 15, 2017 3:41 PM UTC
We are running FME Server 2014
Hi @avone76
Are you planing on keeping an FME Server 2014 installation, or moving and upgrading?
I think in tis situation you are going have to do a reinstall of FME Server, as you can't move the resources/config files post installation.
You can however, do a backup of your server and restore on the new machine. Just in case, I would start up your new FME Server install before removing the old one, just in case you experience issues.
Are you planing to upgrade off 2014 anytime soon?
  • Dec 15, 2017 7:10 PM UTC
Hi @jlutherthomas
Thanks for the sharing.
Yes we are planning to move to FME server 2017 later in 2018, however were in the midst of a DC move and we have dependencies issue. I am trying to figure out if there is any other option that to reinstall our FMe server twice this year.
