Is there a way to trick (or configure) the AffineWarper into non blocking?
  • Aug 1, 2017 5:26 PM UTC
  • 5 replies
  • 125 views
rwhittington
It seems to me that once the Control vectors are sent to the AffineWarper that a single Affine transform could be calculated and applied to all Observed Features as they come through.
Best answer by fmelizard
Sounds like we need a "Control Vectors Come First" mode on that baby. Then we could do as Reed would like. I'll post an idea.
Hi @rwhittington,
Is the main concern the performance of the AffineWarper?
rwhittington
  • Aug 1, 2017 8:59 PM UTC
hi Annabelle, performance. Yes. It seems like it should not need to block if all Control vectors are supplied before Observed features. @DaveAtSafe gave me a tip to use the 3DAffineWarper. So will try that. Thanks for the help.
fmelizard
Forum|alt.badge.img+22
  • Aug 2, 2017 5:26 AM UTC
fmelizard
  • Aug 2, 2017 5:29 AM UTC
Here's the idea: https://knowledge.safe.com/idea/49378/affinewarper-add-control-vectors-come-first-option.html -- go vote! And/or clarify what I've written there. Thanks!
rwhittington
  • Aug 2, 2017 2:09 PM UTC
Thanks Dale.
