Is there a way to check if a directory exists?
gjaguilar
I create a directory B using the mkdir command within one SystemCaller and in another SystemCaller it copies file from directory A to B and it works.
But the process must copy copy new files that are created in directory A and the mkdir gives an error because the directory already exists.
hkingsbury
Forum|alt.badge.img+56
  • March 7, 2024
gjaguilar
  • March 13, 2024
Thanks a lot,
I used this transformer  (FileExistenceChecker) and everything worked fine.
