Is there a way around to convert from Vertices to Line with GPS attributes to keep them ?
  • Aug 6, 2024 4:42 PM UTC
  • 98 views
probert1968
Forum|alt.badge.img+5
Hi friends,
I am trying to do converstion from a vertices to lines that I am working on for a somebody. He use a GPS to track prarire dogs for his work.
So I looked at the shapefile he provided me and it has no GPS. So I create them with the latitude and longtitude.
Β What I am trying to do here is to use the LineBuilder here and then use writer to create a new shapefile…
It came out nothing…
What might I go wrong here ?
Β
I work for US agency and we have FME Desktop 2022.2 version. Do not ask me why.
Β
Thanks
jkr_wrk
Forum|alt.badge.img+37
  • Aug 7, 2024 2:07 PM UTC
Working with FME 2021.2 mostly here. Have 2022, 2023 and 2024 also but no need to use that.
But your question is a bit hard to understand.
You have a shapefile, but the shapefile does not have geometry (what you call GPS). But it has a column lat and long. So you used a VertexCreator to make point geometry. And now you want to convert Point geometry to Line geometry.
This is indeed done with a LineBuilder.
You can connect the LineBuilder to an Inspector to see if the result is as expected.
If that's true then you can start using a FeatureWriter to write the data into a Shapefile. If you set it to the right parameters it should create a Shapefile containing a Line. But for now we don't even know if the data is what you expect so the error could be anywhere.
Β
Β
smclaugh1
Forum|alt.badge.img+8
  • Aug 7, 2024 2:58 PM UTC
It would be helpful to see a copy of your workspace or even a screen capture. You need to createΒ vertices using the coordinates before you use linebuilder and you should assign a coordinate system to the line before you write it to a shapefile.
Β
