Is there a transformer equivalent to ArcGIS Identity?
  • July 1, 2014
  • 136 views
  • July 1, 2014
have a look at the AreaOnAreaOverlayer (http://docs.safe.com/fme/html/FME_Transformers/Default.htm#Transformers/areaonareaoverlayer.htm) and the likes. You can filter the results on the "_overlaps" attribute to control whether you want the union, difference, etc.
David
  • July 1, 2014
depending on the purpose, the Clipper could be also used.
I think the image in this page is similar to Clipper's result (Inside + Outside).
http://resources.arcgis.com/en/help/main/10.1/index.html#//00080000000n000000
Takashi
