Is there a good way to have labels in AR app?
  • May 18, 2020 12:54 PM UTC
  • 86 views
Hi
Just looking at the AR objects, there doesn't seem to be label/text. Would you need to do this via images?
I want to have labels in a street as you pan around.
thanks
itsmatt
Forum|alt.badge.img+48
  • May 18, 2020 1:54 PM UTC
As far as I'm aware there is no real way to label things (although FME 2020 may have improved this)
The output format for FMEAR is essentially obj (you can open the .fmead file with an unzipper and see it all there.
One way to label things might be to use the TextStroker - This will essentially create a vector representation of text features. You can then extrude the shapes into a 3D solid. Not reeeeally a label but might look cool. Not sure if it would really fit your use case.
Good luck!
j.botterill
Forum|alt.badge.img+69
  • Feb 17, 2023 8:10 AM UTC
