Is there a difference between AttributeRemover and Feature.removeAttribute('attr') in the PythonCaller
  • Mar 14, 2022 2:03 PM UTC
  • 55 views
I was wondering, if there is a difference, how the two things work?
I create Lists in a Spatialrelator, and I need to sum over some of their values. As I have a lot of data, I want to remove the lists after summation, and i think feature.removeAttribute('_relationship{}') does the trick. However if I add an AttributeRemover afterwards, under Lists it shows me the _relationship{} List, so it wasn't removed by feature.removeAttribute() ?
Best answer by takashi
Hi @dominikl​ , I think the Python code "feature.removeAttribute('_listname{}')" removes the list definitely, but it won't hide the list name on the GUI. You need to hide the list name with the List to Hide parameter in the PythonCaller, if necessary.
  • Mar 14, 2022 3:15 PM UTC
  • Mar 23, 2022 3:05 PM UTC
Thank you very much :)
