Is it safe to delete FMETEMP files?
  • Nov 9, 2018 1:08 PM UTC
  • 369 views
johnglick
Forum|alt.badge.img+7
My FMETEMP folder keeps growing. I can free up about 1GB by using the purge temporary files feature. However, my entire temp folder is nearly 54GB. Is it safe to manually delete these files? I was thinking they are supposed to go away when I restart the machine, but they seem to stick around.
Best answer by david_r
You can usually safely delete all the files and folders in the FME_TEMP still lingering after having rebooted your machine.
If, for some reason, one or several files are in use, you will not be able to delete them (on Windows) anyway.
  • Nov 9, 2018 1:11 PM UTC
johnglick
  • Nov 9, 2018 1:20 PM UTC
looks like it's mostly coming from FMETable, and I can't delete the files. I'm going to reboot again and try again.
johnglick
  • Nov 9, 2018 1:50 PM UTC
the FMETable folder fills right back up when I run my workspace. I'm going to update my install and see if maybe this was an issue that was fixed.
Forum|alt.badge.img+63
It's FME's temporary data so, depending on your RAM and what you're trying to do, it's normal to see this filling up during a translation.
