Is it possible to zip the output from FeatureWriter?
  • Oct 28, 2022 11:41 AM UTC
  • 162 views
limo
Forum|alt.badge.img+8
I have to zip the output from the featurewriter.
The standard writer has the option to zip the output. Is this also possible with transformer "FeatureWriter"? I have not found anything about it.
I need FeatureWriter because my process will go on after writing!
Best answer by ebygomm
Yes, it's possible
There should be an option if you click the down triangle alongside the dataset parameter
Forum|alt.badge.img+54
  • Oct 28, 2022 11:52 AM UTC
Yes, it's possible
limo
  • Nov 3, 2022 7:07 AM UTC
Yes you are right! I haven´t seen it.
thanks @ebygomm​
