Is it possible to find out the width of a polygon using FME tranformers?
  • February 17, 2015
  • 173 views
I have a large polygon dataset within which there exist some long thin polygons that i wish to isolate.. is there a way i can achieve this through the use of FME?????
I understand there is something similar in ArcMap that works out the average length and width of a polygon, if i could replicate this using FME i would be most happy.
  • February 17, 2015
maybe the BoundsExtractor followed by an ExpressionEvaluator to calculate the difference between x-max and x-min?
David
  • February 18, 2015
That worked a treat! thanks very much!
