Is it possible to create a Steiner Tree algorithm using FME?
I found an example of the minimum spanning tree but wondering if it is possible to do Steiner Tree. I have the Edges, Nodes and Steiner Nodes all created but I want the optimal undirected route to connect all the Nodes.
danilo_fme
Forum|alt.badge.img+42
Hi @joeburns,
I believe you can to do using the transformer PythonCaller. I found this link on git hub Steiner tree Python
The transformer StreamOrderCalculator works with Strahler and Horton method.
Thanks,
Danilo
danilo_fme wrote:
Hi @joeburns,
Thanks,
Danilo
I have tried the PythonCaller and one or two of the examples on the knowledge forum but whenever I try to send the PythonCaller two input transformers (one points, the other lines) the script always seems to treat them as a single input and not as two separate entities. Do you know how to pass two datasets through the PythonCaller to a Python script?
danilo_fme
Could you share your Workspace template ( .fmwt ) ?
This is the basis of what I am trying to achieve. I have tried to edit the python script but have been unsuccessful (not very experienced with Python).
steinertree.fmwt
