Intersect Rivers x Contour Elevation
  • Mar 31, 2015 12:52 PM UTC
  • 5 replies
  • 69 views
hello ' m trying to make generate a point shapefile in places where the river crosses two or more times the same elevation contour
gio
Forum|alt.badge.img+15
  • Mar 31, 2015 3:57 PM UTC
SpatialRelator with River as requestor and contours as supplier.
Explode "_related_candidates" and then rebuild list with Contour_ID as GroupBy.
Count elements of list or use a listhistogrammer. Build list for counts>1 with river_ID as GroupBy.
This gives the contours crossed more then once per river.
  • Mar 31, 2015 4:21 PM UTC
If the goal is to generate point features, the following procedure may be a solution.
Assuming that the river lines have an attribute called "_river_name" and the contour lines have "_elevation" that stores the elevation value.
(1) Send all river and contour lines to a LineOnLineOverlayer together.
List Name: _list
(2) Send the resulting intersection points to a ListExploder.
List Attribute: _list{}
Accumulation Mode: Only Use Incoming List  <= important
(3) Send the output points to a Matcher.
Match Geometry: 2D
(4) Send the points that will be output from the SingleMatched port of the Matcher to a StatisticsCalculater.
Group By: _river_name, _elevation
Attributes to Analyze: <any>
Total Count Attribute: _count
The points that will be output from the Complete port of the StatisticsCalculator are the intersections between rivers and contour lines. The points will have "_river_name", "_elevation", and "_count".
The "_count" stores the number of intersection points between the river and the contour line.
Takashi
  • Mar 31, 2015 4:27 PM UTC
Here's a sample solution using Intersector.
https://drive.google.com/file/d/0B9AOve1u6FfELWhoTkJfTGQ1TTg/view?usp=sharing
Regards,
Pierre
  • Mar 31, 2015 4:42 PM UTC
sorry, my previous solution was too redundant.
It's not necessary to use the ListExploder and the Matcher.
Just send the intersection points that are output from the Point port of the LineOnLineOverlayer to the StatisticsCalculator.
gio
  • Apr 1, 2015 3:09 PM UTC
After relating you have the objects related, enough info to create the interstionpoints.
