Interpolation of GPX GPS log
How can I interpolate a GPX track? TrackPoints were logged every 2 seconds, exceptionally every second. For my application I need 1Hz. So I want to interpolate xy coordinates to every second.
1
roland.martin
Forum|alt.badge.img+9
It's a little bit convoluted, but this is how I've done it before (this is from memory, so apologies for any transformer name mismatches!)
1. Parse timestamps - use a DateFormatter to convert to seconds since epoch (%s)
2. Set timestamps as measure (MeasureSetter)
3. Create line features (LineJoiner)
4. Snip at 1 second intervals (Snipper)
This should get you most of the way - post again if you get stuck!
  • November 10, 2015
Hi
Also look at the Densifier transformer.
David
