Intergraph-mdb metadata missing
  • March 10, 2015
  • 0 replies
  • 26 views
Dear all,
I have a question concerning intergraph-mdb datasets but I am not sure whether I am doing just something wrong or if it is a problem with FME itself. When I create an intergraph-mdb reader and connect it straight to an intergraph-mdb writer, FME writes the mdb without any warning or error. When I look at the resulting database by using the data inspector, everything seems to be fine, too. But when I open the mdb in the program "Intergraph GeoMedia", it tells me that it does not know the reference system (although I set it explicitly in the writer's properties and FME itself recognizes it). Further investigations revealed that GeoMedia cannot read the reference system due to a lack of the necessary metadata (GeoMedia reports "not enough GeoMedia system metadata").
Has anyone else also observed this problem or am I doing something wrong?
Best regards
André
