Inserting newlines in XML Templater?
  • June 7, 2017
  • 211 views
Hi!
My XML Templater workflow is as follows: One feature triggers the root template, that then processes three subtemplates. However, I can't get the subtemplates to begin on a new line.
Current state:
</node><node id="80000000010000007000" attributes="">
<tags>...</tags>
</node><node id="80000000010000007001" attributes="">
    <tags>...</tags>
</node><node id="80000000010000007002...
Desired state:
</node>
<tags>...</tags>
</node>
    <tags>...</tags>
</node>
But I can't seem to work out how to get a newline in there. I've tried both some CDATA-suggestion from https://stackoverflow.com/questions/10917555/adding-a-new-line-break-tag-in-xml as well as
 - neither of which are permitted.
  • June 7, 2017
Hi @fhilding, I don't think there is a good way to do that within the XMLTemplater. Consider using the XMLFormatter if you need to adjust the format of the resulting XML document.
  • June 7, 2017
Of course! Almost silly of me to forget that there's also a formatter :) Thanks!
