Insert New Item/Child into an Existing XML Element List
  • February 27, 2024
  • 178 views
mmccart
Forum|alt.badge.img+16
I am trying to insert a new item/child into an existing XML element.
I want to add: <keyword>USA</keyword> to either the top of this list of keywords (Note this is part of a larger XML document.)
I’ve tried to use the XMLUpdater to no avail after a substantial Forum search.
Here’s where I am at with the XMLUpdater:
I assume my XML/XQuery expression is the issue. Any help would be appreciated.
Thanks in advance!
Version: FME 2022.2.0.0 (Build22765)
Best answer by mmccart
Thank you @debbiatsafe! That does what I need.
debbiatsafe
Forum|alt.badge.img+20
  • February 27, 2024
Hi @mmccart
Since you want the new keyword element to be a child of the placeKeys element, the XML Path parameter should be: //dataIdInfo/placeKeys
The Value parameter should be <keyword>USA</keyword> as you want to insert a new element and not an attribute
I hope this information helps!
mmccart
  • February 27, 2024
