Indexing attribute columns in Precisely MapInfo Extended TAB
  • Feb 19, 2026 11:55 PM UTC
  • 99 views
nicholas
Forum|alt.badge.img+14
I am using the Precisely MapInfo Extended TAB Writer to generate a MapInfo table that is over 2GB (total) in file size. I estimate it should be between 3GB and 4GB in size.
I am indexing five attribute columns in the table.
And the process of indexing the attribute columns is extremely slow.
When I do not index any columns, it takes about 20 minutes to Write the table
With indexing the columns, it can run for twelve hours before I halt the process in frustration to check my process.
Does anyone have any experience of this? Is the Precisely MapInfo Extended TAB Writer just bad at generating indexes?
j.botterill
Forum|alt.badge.img+69
  • Feb 20, 2026 7:34 AM UTC
Indexes are created incrementally during the write
Each attribute index is written to the .IND file, and the critical point is:
MapInfo builds attribute indexes row‑by‑row, not as a bulk post-process
Dropping even one index can halve runtime.
Avoid indexing text fields if at all possible
Consider writing the geometry TAB with minimal attributes
Write the attributes-only to a DBF
Join the two in mapinfo downstream
nicholas
  • Feb 23, 2026 4:51 AM UTC
Hi ​@j.botterill  from where do you get that quote?
I have been reading the FME help docs on the Precisely MapInfo Extended TAB Writer and I cannot see a mention of “MapInfo builds attribute indexes row‑by‑row, not as a bulk post-process”
But I may be looking in the wrong place
j.botterill
  • Feb 26, 2026 1:01 AM UTC
I got that info from mapinfo sources about the format itself
nicholas
  • Feb 26, 2026 1:14 AM UTC
I use MapInfo often, and it is absolutely possible to build an Index on a column after all the records have been inserted.
For large datasets, a common optimisation is to drop the indexes, make the changes and then re-build the indexes.
