Identify overlapping areas in a single source data
  • Jan 31, 2018 3:04 AM UTC
  • 9 replies
  • 441 views
anthrax_79
Forum|alt.badge.img+4
I would like to identify overlaps but only from a single source of data. That data has 1500+ records of unique Region Name. However, I found an instance where a part of a region is overlapping another adjacent region. I would like to identify how many instances I have in my database identifying at least 1 region name and creating an area of the overlapped.
as shown below, green area has a portion of the adjacent boundary.
any help is appreciated.
thanks
Lex
Best answer by gtihon
Area on area overlayer and then you filter the results based on attribute _overlaps
pratap
Forum|alt.badge.img+12
  • Jan 31, 2018 3:41 AM UTC
Have you tried AreaOnAreaOverlayer?
Pratap
anthrax_79
  • Jan 31, 2018 8:03 PM UTC
Pratap
Yes, but it seems to not work. :(
pratap
  • Feb 1, 2018 5:02 AM UTC
Is it not solved? then could you kindly upload the area where it fails
Pratap
anthrax_79
  • Feb 1, 2018 8:27 PM UTC
Pratap
Created just a simple workspace. not really sure about it.
1 and 2 are separate areas and 3 is the overlap.
I'm afraid I still have a lot of gaps and slivers (very minimal value)
  • Feb 1, 2018 9:24 PM UTC
  • Feb 1, 2018 10:38 PM UTC
First of all, as @gtihon suggested, take a look at the attribute called "_overlaps" in the features output from the AreaOnAreaOverlayer. See the help on the transformer to learn more about the Overlap Count Attribute.
I don't know why the AreaBuilder is needed here.
anthrax_79
  • Feb 2, 2018 1:18 AM UTC
I'm still learning and discovering FME. I've missed the part where AreaOnArea finds the overlaps and extract them into a new geometry. I think, I just got confused with the output. was not expecting to see 12k overlaps.
thanks for your reply
Lex
anthrax_79
  • Feb 2, 2018 1:43 AM UTC
I think I got it now. Thanks for the help guys! now the output makes sense. I was missing a transformer as you have mentioned @gtihon. "Tester"
Now that I have identified these. next step is finding Gaps and slivers.I will see how I go with those.
Cheers
Lex
pratap
  • Feb 2, 2018 6:48 AM UTC
I understood your requirement now after looking your workbench.
AreaOnAreaOverlayer will break the polygons and again we have to build it back.
Try SpatialFilter.
Pratap
