I would like to transform a GeoJSON file into a line feature
  • May 25, 2021 11:59 AM UTC
  • 98 views
Hello everyone,
I'm currently trying to make a path from a GEOJSON "link" which was return from a HTTPCaller. Is there any way to transform the link below into a line feature?
Thank you in advance.
{"code":"Ok","waypoints":[{"hint":"xPMEgEswB4AKAAAAAAAAAFcAAAAAAAAAJ0k3QQAAAADB2cBCAAAAAAoAAAAAAAAAVwAAAAAAAADaAAAAC07F-1foygJzT8X7X-bKAggAnw0GXKGa","location":[-70.955509,46.852183],"name":"Rue du Moulin"},{"hint":"4nEJgIjqCYAMAAAABQAAAH0AAAAaAAAAUXXHQaFyEkF2A31DScJOQgwAAAAFAAAAfQAAABoAAADaAAAAAVjF-47pygK1V8X7u-nKAgUA3w0GXKGa","location":[-70.952959,46.852494],"name":"Route du Fleuve"}],"routes":[{"legs":[{"steps":[{"intersections":[{"out":0,"entry":[true],"location":[-70.955509,46.852183],"bearings":[37]}],"driving_side":"right","geometry":{"coordinates":[[-70.955509,46.852183],[-70.955418,46.852265],[-70.955302,46.852347],[-70.955159,46.852438],[-70.955029,46.852529],[-70.954991,46.852556],[-70.9549,46.85262],[-70.954744,46.852703],[-70.954575,46.852812],[-70.954497,46.852858]],"type":"LineString"},"duration":12.6,"distance":107.8,"name":"Rue du Moulin","weight":12.6,"mode":"driving","maneuver":{"bearing_after":37,"location":[-70.955509,46.852183],"type":"depart","bearing_before":0,"modifier":"right"}},{"intersections":[{"out":1,"in":2,"entry":[true,true,false,true],"location":[-70.954497,46.852858],"bearings":[45,150,225,315]}],"driving_side":"right","geometry":{"coordinates":[[-70.954497,46.852858],[-70.954337,46.852697],[-70.954164,46.852546],[-70.954058,46.852483],[-70.953965,46.852421],[-70.953753,46.852297],[-70.95362,46.85219],[-70.953481,46.85208]],"type":"LineString"},"duration":16.7,"distance":116.6,"name":"Rue Péan","weight":16.7,"mode":"driving","maneuver":{"bearing_after":144,"location":[-70.954497,46.852858],"type":"turn","bearing_before":47,"modifier":"right"}},{"intersections":[{"out":0,"in":2,"entry":[true,true,false],"location":[-70.953481,46.85208],"bearings":[45,225,315]}],"driving_side":"right","geometry":{"coordinates":[[-70.953481,46.85208],[-70.953308,46.852218],[-70.953118,46.852369],[-70.953038,46.852432],[-70.952959,46.852494]],"type":"LineString"},"duration":3.1,"distance":60.8,"name":"Route du Fleuve","weight":3.1,"mode":"driving","maneuver":{"bearing_after":40,"location":[-70.953481,46.85208],"type":"turn","bearing_before":139,"modifier":"left"}},{"intersections":[{"in":0,"entry":[true],"location":[-70.952959,46.852494],"bearings":[221]}],"driving_side":"right","geometry":{"coordinates":[[-70.952959,46.852494],[-70.952959,46.852494]],"type":"LineString"},"duration":0,"distance":0,"name":"Route du Fleuve","weight":0,"mode":"driving","maneuver":{"bearing_after":0,"location":[-70.952959,46.852494],"type":"arrive","bearing_before":41,"modifier":"left"}}],"weight":32.4,"distance":285.1,"summary":"Rue du Moulin, Rue Péan","duration":32.4}],"weight_name":"routability","geometry":{"coordinates":[[-70.955509,46.852183],[-70.955418,46.852265],[-70.955302,46.852347],[-70.955159,46.852438],[-70.955029,46.852529],[-70.954991,46.852556],[-70.9549,46.85262],[-70.954744,46.852703],[-70.954575,46.852812],[-70.954497,46.852858],[-70.954337,46.852697],[-70.954164,46.852546],[-70.954058,46.852483],[-70.953965,46.852421],[-70.953753,46.852297],[-70.95362,46.85219],[-70.953481,46.85208],[-70.953308,46.852218],[-70.953118,46.852369],[-70.953038,46.852432],[-70.952959,46.852494]],"type":"LineString"},"weight":32.4,"distance":285.1,"duration":32.4}]}
nampreetatsafe
Forum|alt.badge.img+14
Great to see that you received a solution here!
