I would like to know how I can transfer z-coordinates from nearest neighbour point features to all the vertices of a polyline in such a way that each vertex gets a unique z (so multiple unique z's per polyline)?
  • Oct 23, 2022 4:20 PM UTC
  • 12 replies
  • 208 views
The Z-coordinates are not the same and varying. The points are located within a buffer of 0.1meter and extend over the entire area of the polyline. I have to join them based on a search area I think of 0.1 meters. The points are created from a las and transformed using the pointcloudtopointcourcer. As an example, I would like to have for this polyline which has 5 vertices 5 unique z-values from the closest points.
Best answer by daveatsafe
Hi @sibe​,
It may be possible to do this with the NeighborFinder and some vertex manipulation in Python, but the simplest way to get the same result would be use the SurfaceDraper transformer with the original compete las file used for the Points/Lines input.
daveatsafe
Forum|alt.badge.img+24
  • Oct 24, 2022 8:52 PM UTC
Hi @sibe​,
  • Oct 24, 2022 10:14 PM UTC
Thank you very much. I got it working :) One question, the breaklines parameter I don't understand. What is the breaklines feature used for?
  • Oct 24, 2022 10:15 PM UTC
It seems this tool is always using some kind of interpolation. Is it also possible to only take the closest point for the Z-coordinate?
daveatsafe
  • Oct 24, 2022 10:18 PM UTC
Breaklines are used to force the edges of the generated triangles into a desired orientation. For example, road edges are often used as breaklines, to ensure that edges in the triangulation follow the edge of the road. This gives you better definition in the resulting surface.
daveatsafe
  • Oct 24, 2022 10:21 PM UTC
Please set the Interpolation to CONSTANT to use the Z value of the closest vertex.
  • Oct 24, 2022 10:33 PM UTC
I tried that, but it seems it doesn't take the closest value in some instances. For this vertex it assigned a Z of +0.06, while the closest point was -0.149? The point was located within the surface tolerance of 0.25. Drape method set to VERTEX and existing elevation Replace Z.
daveatsafe
  • Oct 24, 2022 10:36 PM UTC
Try setting the surface tolerance to 0.
  • Oct 24, 2022 10:47 PM UTC
That did it thank you
  • Mar 2, 2023 9:46 PM UTC
Hi, one more question regarding the constant interpolation in the surface draper tool. For the constant interpolation the documentation says: ''Interpolation method: CONSTANT: The z value of each output point is set to the z value of the closest vertex in the underlying model.'' Does this mean X, Y and Z is taken into account when the closest Z value is joined from the LAS to the 2D feature vertex? (surface tolerance is set to 0)
daveatsafe
  • Mar 3, 2023 5:53 PM UTC
The X and Y are used to determine the closest vertex. The Z is used to set the elevation on the draped feature.
  • Mar 3, 2023 6:00 PM UTC
Just to clarify for me: Does this mean that when the constant interpolation method is used in the surface draper tool that no Delaunay triangulation is used? Or that Delauney Triangulation is used but only looking at X, Y to find the nearest neighbour as you stated. The Z is then copied based on X, Y nearest neighbour.
daveatsafe
  • Mar 3, 2023 9:25 PM UTC
The Delauney triangulation is done in either case, to make use of the Surface Tolerance filtering. The nearest surface vertex in XY to the drapee vertex is used to supply the Z value.
