I would like to extrude footprint which is available in Shape file till Building roofs, But extruded buildings are above the given building roof, Even I am not able clip the extruded buildings. Any suggestions and solutions if any?
  • Jan 24, 2024 10:36 AM UTC
  • 88 views
aruja2000
Best answer by daveatsafe
Hi @aruja2000​,
Would extruding down instead of up from the roof lines help? You can do this by using a negative extrusion value.
daveatsafe
Forum|alt.badge.img+24
  • Jan 24, 2024 5:23 PM UTC
Hi @aruja2000​,
aruja2000
  • Jan 25, 2024 2:25 AM UTC
Thanks for the solution, will do the same and come back with the results.
