I would like to extract the second last word in a string using StringSearcher but I'm inexperienced in RegEx. Any suggestions?
  • Dec 6, 2017 6:29 PM UTC
  • 8 replies
  • 306 views
fmelizard
Forum|alt.badge.img+22
  • Dec 6, 2017 6:33 PM UTC
You could also consider using an AttributeSplitter, split based on space character: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/attributesplitter.htm
Then expose the list element containing the second last word, using the AttributeCreator or AttributeManager. For example expose list element 3, list{2} and rename to a suitable attribute name.
erik_jan
Forum|alt.badge.img+26
  • Dec 6, 2017 6:53 PM UTC
Good suggestion @NatalieAtSafe.
As an addition: the second last word will be list element -2 (e.g list{-2}).
  • Dec 6, 2017 9:36 PM UTC
@NatalieAtSafe I like this approach, but I'm having a little trouble getting any output results. I'm guessing I'm not entering the fields correctly, and the list elements are not showing up on the output table. Is there any way to contact you directly and get some assistance? Thanks.
erik_jan
  • Dec 6, 2017 10:18 PM UTC
I have created a sample workspace:
find-sondlast.fmw
  • Dec 6, 2017 10:28 PM UTC
find-sondlast.fmw
That's fantastic...worked perfectly. Thanks very much for your help!
fmelizard
  • Dec 6, 2017 11:18 PM UTC
find-sondlast.fmw
Thank you @erik_jan
  • Dec 7, 2017 7:16 AM UTC
find-sondlast.fmw
Alternatively, the ListIndexer can be used here. e.g.
paalped
Forum|alt.badge.img+11
  • Dec 7, 2017 10:11 AM UTC
use a onliner in pythoncaller:
in input function write:
feature.setAttribute('Your_new_attribute',feature.getAttribute('attribute_with_words_i_want_the_second_last').split(' ')[-2])
