I've found that when providing an excel worksheet name via the initiator for the feature reader transformer, it can't find a sheet that has spaces in its name i.e. 'as at 30Nov20', but it can find the same sheet if I rename 'as_at_30Nov20'.
  • May 12, 2021 2:17 AM UTC
  • 98 views
garyhk
Is there some setting that needs changed?​
Best answer by nielsgerrits
Because of the spaces, you need to put the sheet name between quotation marks. So instead of
as at 30Nov20
you have to use
"as at 30Nov20"
2021-05-12_07h21_02
nielsgerrits
Forum|alt.badge.img+67
  • May 12, 2021 5:20 AM UTC
as at 30Nov20
you have to use
"as at 30Nov20"
2021-05-12_07h21_02
@garyhk​ Thanks for raising this issue. @nielsgerrits​ has given you a workaround, but this is something we'll try and fix in a future release.
garyhk
  • May 12, 2021 8:36 PM UTC
​Thanks for the replies especially @nielsgerrits​. Using a stringconcatenator  to add double quotes has fixed the issue for me.
