I try to convert Autocad Dwf to Autocad DWG but the Text height is not changing during write stage. I force the autocad_text_size , autocad_box_height, and autocad_box_width.
  • Jan 19, 2023 6:07 PM UTC
  • 119 views
billschooler
I force the autocad_text_size = @Evaluate(@Value(autocad_text_size) / 100), autocad_box_height = @Evaluate(@Value(autocad_box_height, and autocad_box_width = @Evaluate(@Value(autocad_box_width) / 100).
When viewing the Attribute Creator transformer value they look correct but when I open AutoCAD DWG file the text is still at the original height.
I try using TextAdder and DWG styler but nothing seem to work.
Can someone show me what I am doing incorrectly in my workspace?
caracadrian
Forum|alt.badge.img+23
  • Jan 19, 2023 7:10 PM UTC
Try this:
In AttributeManager create a new attribute with the value autocad_text_size( /100 if you need), move autocad_text_size to the bottom of the list and remove it. Also expose and remove autocad_original_text_size, autocad_mtext_text_height.
In a second AttributeManager create an autocad_text_size attribute and set its value from the previous created attribute. Sometimes it's ok if you just rename it to autocad_text_size but create a new one to be sure.
FME passes Autocad specific attributes if you don't expose and remove them. Text size is stored in multiple attributes.
Let me know if it works for you.
DWG_text_size overwrite
f.kemminje
Forum|alt.badge.img+11
  • Jan 21, 2023 5:24 AM UTC
The easiest would be.
read acad text
expose fme_text_string attribute
use labelpointreplacer transformer, change text height
write to acad
