I need to use the first last vertices of a multiple vertex line to pull info from a neighbor
  • May 24, 2018 5:52 PM UTC
  • 175 views
I've figured out how to get the vertex info (Coordinate Extractor for Vertex (0) & vertex (-1)) but there doe snot appear to be a simple way to do this. What I am looking for is functionally similar to NeighborFinder. I'm in the telecom industry & I have fiber that is running down a line of poles At each end of the fiber I need to get the PoleID for the nearest Pole & add it to FromPole & ToPole fields. If NeighborFinder would work off of vertex references or X/Y Attributes it would be simple BUT it does not so I need some help.
Any Ideas - preferably using native FME 2017.1 only
austinh
Forum|alt.badge.img+4
  • May 24, 2018 6:35 PM UTC
Try using the Snipper transformer to get your fiber start and end points.
