I'm trying to copy metadata from SDE (Test) to SDE (Prod) environment. Any help would be greatly appreciated.
  • Sep 22, 2023 7:32 PM UTC
  • 39 views
joepk
Forum|alt.badge.img+22
  • Sep 25, 2023 6:51 AM UTC
You can set the SDE reader to read only metadata: imageTo write the metadata, set the geodb_type atribute of the feature containing the metadata to 'geodb_metadata'. More information and examples can be found here: Working with Geodatabase Metadata: Writing/Updating Metadata
