I have two tab files and while joining them I get this error for one of the row ERROR |FeatureJoiner (FeatureJoinerFactory): The UTF-16LE string 'DOÃƑ±A ANA-HILL' could not be converted to the encoding: windows-1252.
  • Mar 10, 2023 3:14 AM UTC
  • 6 replies
  • 90 views
@csj5483​ What version of FME are you using? Newer versions of FME might handle this a little better. If not are you able to attach a small sample dataset? Alternatively, the MapInfo (MITAB) reader has an option to set the Character Encoding, or try the AttributeEncoder
  • Nov 16, 2023 12:40 PM UTC
Is there any way if this exception occur we can skip that record. I have around 200 Million rows in tab file.
evieatsafe
Forum|alt.badge.img+28
  • Nov 28, 2023 7:40 PM UTC
Hi @csj5483​ if you turn on "Rejected Feature Handling" to "Continue Translation" this should continue to join your features without terminating the translation. Hope that helps!
  • Nov 29, 2023 6:10 AM UTC
Hey @Evie Lapalme​ We're already using this option.
evieatsafe
  • Nov 29, 2023 6:30 PM UTC
Great! With this set, is it not continuing the translation? What version of FME are you using? Could you share your full log file? Have you tried an AttributeEncoder like Mark suggested? If this is urgent, perhaps you could submit a support case with us including this information. Happy to help :)
  • Nov 30, 2023 5:59 AM UTC
I have raised support case and also attached log file.
https://community.safe.com/s/case/500Dm00000K5noMIAR/error-while-performing-feature-joiner
