i have two geometry point and shape in dgn format.i want to create a point based polygon,i tried point on area overlayer it works fine.but output polygon was the samename,didnot take the point levelname.here i attched my input dgn.
  • Aug 12, 2019 5:11 AM UTC
  • 36 views
Forum|alt.badge.img+63
If you set the PointOnAreaOverlayer's Attribute Accumulation Parameters like this:
So accumulation mode to Merge Incoming and conflict resolution to Use Incoming any attributes of the points will overwrite matching attributes on the shapes.
You may also want to consider adding a list, there's 4 points overlapping 1 shape in your example.
