i have the GPS coordinates in TM Projection.how to convert these coordinates for U T M Projections...for example my TM Coordinates are 826733.62,1207662.619.and my U T M coordinates are 826762.8,1207658.583
  • Oct 3, 2018 5:22 AM UTC
  • 92 views
thirug
Projections Changes
oscard
Forum|alt.badge.img+23
  • Oct 3, 2018 6:03 AM UTC
Does the Reprojector transformer work for you?
thirug
  • Oct 3, 2018 6:56 AM UTC
Thanks for reply,i worked that reprojecter but don't change.it changes the UTM zones
Forum|alt.badge.img+63
For clarification:
  • Do you have geometry or are those coordinates stored in attributes (in which case you'll need to use the AttributeReprojector)?
  • What format is your data in?
  • Do you know which UTM zone your data is in?
thirug
  • Oct 5, 2018 5:12 AM UTC
i have the dwg file.it was fully procseed the TM Coordinates.i want to change the WGS84 43 N Zone.
