I have modeled a building using AutoDesk MAYA, I would like to import it into ESRI ArcGIS Pro. The issue is that once I have imported my .obj 3D file, it appears as a single model and not as a set of elements (walls, floors, roof, etc.) as I would l
  • Jun 16, 2021 2:45 PM UTC
  • 0 replies
  • 29 views
I could import it into 3DS MAX and then export it as a callada file, 3DS file or VRML file, but it still does not appear with independent elements.
Do you have an idea to help me resolve this issue ? Do you know an FME transformer that could separate/disjoin my 3D file ?
