I have added an extra column in the shapefile using attribute manager. How can I edit the values in that column?
  • May 16, 2022 9:31 AM UTC
  • 9 replies
  • 146 views
geogaard
Forum|alt.badge.img+15
  • May 16, 2022 9:36 AM UTC
If you want to edit the value when you create the attribute you do it directly in the AttributeManager like this:
Else you might want to specify what you are trying to do with an example :)
bilde
  • May 16, 2022 9:44 AM UTC
bilde
image.png I am trying to add some data in the column 'additional information' manually. And each field would have different values. How do I do that? There are around 10 rows and each row would have different value in the additional informal column. How do I set the permission to manually edit it individually ?
geogaard
  • May 16, 2022 9:51 AM UTC
If you can do it based on rules you would use the conditional value? Would that work you think?
  • May 16, 2022 10:00 AM UTC
The attribute information I want is to add is not conditional nor it is related to any already existing attributes. It would be a completely new value ( descriptive string value) and would be different for each row. So I guess using conditional value won't work.
geogaard
  • May 16, 2022 10:13 AM UTC
So it seems. Are you looking for a table view of all the attributes and editing in that sort environement?
  • May 16, 2022 10:52 AM UTC
Yes, That is true. I have difficulty with how to do that.
geomancer
Forum|alt.badge.img+71
  • May 16, 2022 12:42 PM UTC
This is possible with a conditional value, at least when there is some relation between the existing attributes and the descriptive string values you want to add:
Conditional ValueIn that case you can also add the descriptive string values by reading an external file, and then using a FeatureJoiner.
geogaard
  • May 16, 2022 1:10 PM UTC
I would consider adding that data in Excel, QGIS, ArcGIS or something similar and then running it through FME
  • May 16, 2022 6:58 PM UTC
Thank you for the suggestions
