i have a user parameter that i would like to use as a filter for a second user parameter
  • Jan 21, 2022 8:27 PM UTC
  • 68 views
slade_bridges
i have seen numerous posts about this but i cant get a good working solution. i have a user parameter that i want to limit a second user parameter based on the selection of the first. so far i can get a filter on the first parameter but how do you link the second parameter to the first in order to present the user with only the attributes that match the first parameter?
@slade_bridges​ Newer versions of FME (2021 and up) introduced a tree view for parameters in the new Parameter Manager. This might give you what you want.
dialogand the user sees:
dialog1
slade_bridges
dialog1
@Mark Stoakes​ i did try that, but when a user selects multiple selections, no KMZ is exported
