I have a shapefile with 1000 polygon data and shapefile includes 50000 unique lines. I want to connect both lines that are inside the polygon. I used the spacialfilter but it couldn't detect properly endpoint of the lines which are inside of the po
  • May 3, 2023 1:10 PM UTC
  • 33 views
myadegaryiutac
Forum|alt.badge.img+11
I have a shapefile with 1000 polygon data and shapefile includes 50000 unique lines. I want to connect both lines that are inside the polygon. I used the spacialfilter but it couldn't detect properly endpoint of the lines which are inside of the polygon
dustin
Forum|alt.badge.img+36
  • May 3, 2023 1:34 PM UTC
Could you post a screenshot or sample data of what you are trying to accomplish?
myadegaryiutac
@dustin​
Here is an example of a different situation.
I want to detect those lines which are inside of the polygon like locations 1 and 2, and then snap/connect those lines together.
In the next category I want to detect those lines which have 5 cm distance from the polygons. and snap/connect them inside of the polygons (like location 4)
Screenshot 2023-05-03 at 3.48.02 PM
