I have a point cloud that needs to be transformed from one projection to another, using specific 7 parameters. I've tried Reprojector and EsriReprojector but none of them allowed the usage of specific parameters. I'm new to FME so sorry in advance, t
  • Oct 20, 2020 11:49 AM UTC
  • 51 views
I have a point cloud that needs to be transformed from one projection to another, using specific 7 parameters. I've tried Reprojector and EsriReprojector but none of them allowed the usage of specific parameters. I'm new to FME so sorry in advance, thanks
Best answer by jlbaker2779
See the custom projection help below. It should point you in the right direction. Following this guild will create a shared projection that can be used in the transformers.
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Coordinate_Systems/Workbench/coordinate_sys_custom_about.htm
  • Oct 20, 2020 11:58 AM UTC
  • Oct 20, 2020 12:59 PM UTC
Thank you. I think the problem is solved! Best regards!
