i have a huge data of GeoRSS. i want to convert it to shapefile. i can convert all my data with fme but projection and attributes are not coming? i attached a sample coding below.
  • Feb 19, 2022 5:19 PM UTC
  • 6 replies
  • 81 views
<ul class="textattributes">
 <li><strong><span class="atr-name">code</span>:</strong> <span class="atr-value">01</span></li>
 <li><strong><span class="atr-name">teh_nm</span>:</strong> <span class="atr-value">Adhartal</span></li>
</ul>
]]></description><georss:polygon>23.263113894134655 79.9657965013572 23.263116605734016 79.96581753147373 23.263121042554495 79.96583425568379 23.26312856542468 79.96585814323883 23.26313967034197 79.96589970121278 23.26315331921497 79.96597267824511</georss:polygon></item><item>
danilo_fme
Forum|alt.badge.img+58
  • Feb 19, 2022 7:09 PM UTC
Please, attached here your file.
danilo_fme
  • Feb 19, 2022 7:13 PM UTC
@sonekar7​ have you tried the use the transformer GeometryExtractor and set the configuration Geometry Enconding: GeoRSS Simple?
GemetryExtractor
Thanks in Advance,
Danilo
  • Feb 19, 2022 7:41 PM UTC
  • Feb 19, 2022 7:43 PM UTC
GemetryExtractor
Thanks in Advance,
Danilo
i m new to use fme desktop..i used htmlextractor but not working. i m missing sometine, i dont know what.
  • Feb 21, 2022 8:42 AM UTC
Here is the link https://drive.google.com/file/d/1Y0o0lH34ZB80fFG1RWiSnb2ErMopIS1Q/view?usp=sharing
here is the link of file that i have to convert in Shapefile with coordinate
  • Feb 21, 2022 9:15 AM UTC
Screenshot 2022-02-21 144156i am using this for conversion
