I don't know how to create a new coordinate system for Spain
  • Jul 14, 2020 5:51 PM UTC
  • 41 views
Hello,
I have a Smallworld database in a coordinate system that I cannot find (or are not) in FME Workbench.
The main data:
- Datum: ETRS89
- Ellipsoid: GRS80
- Type of Projection: Cylindrical, North UTM
- Zone: 30
- Origin of Latitudes: 0.000 m
- Origin of Lengths: -4000000.000 m
- Units: mm
I have tried the Safe web assistant but I think something is wrong. It looks like this:
COORDINATE_SYSTEM_DEF Prueba_CABB \\
DESC_NM "Para CABB" \\
DT_NAME ETRS89/01 \\
PARM1 30 \\
PARM2 1 \\
PROJ UTM \\
QUAD 1 \\
UNIT METER \\
ZERO X 0.000 \\
ZERO_Y -4000000.000
But I'm not sure it's correct.
I would greatly appreciate your help
Regards
Luis
daveatsafe
Forum|alt.badge.img+24
  • Jul 14, 2020 9:35 PM UTC
Hi @lucho,
The UTM projection doesn't allow any settings other than datum, zone and hemisphere. It might be better to use the TM projection instead, which is the same projection, but allows a bit more customization. I think a good match for your coordinate system would be:
    DESC_NM "Prueba_CABB" \
    DT_NAME ETRS89/01 \
    ORG_LAT 0 \
    PARM1 -3 \
    PROJ TM \
    QUAD 1 \
    SCL_RED 0.9996 \
    UNIT MILLIMETER \
    X_OFF 0 \
    Y_OFF -4000000000
The units are set to MM, and the Y_OFF is set in MM.
