I can draw lines on a raster and then save as a jpg. Why can't I put text on the raster and convert to jpg too?
  • September 10, 2017
  • 108 views
I wish to add text record of attributes to jpgs. I am creating a workspace runner to do this. However, I cannot get the text to be applied to the raster. I can see that the text is created in Inspector, but Vector on Raster overlayer does not write the text to the new raster. (See workspace)
I tried mapnikrasterizer with even less success; I couldn't get any product from the jpg writer.
This seems like it should be a simple fix.
Your help is much appreciated,
William
Best answer by danilo_fme
Hi @wellis11,
I simulated here in my machine your case.
For to put your text inside the raster file, you need to use the transformer TextStroker after the transformer FeatureColorSetter_3 .
And my Writer JPEG file was generated with the Text Hello.
Thanks,
Danilo
danilo_fme
Forum|alt.badge.img+57
Hi @wellis11,
Thanks,
Danilo
Hi @wellis11,
Thanks,
Danilo
Success! Thank you so much!
Your solution worked like a charm.
Sincerely,
William
danilo_fme
Sincerely,
William
Hi @wellis11,
I'm happy to your problem has a good solution.
Thanks,
Danilo
Forum|alt.badge.img+63
In addition to @danilo_inovacao's suggestion, the MapnikRasterizer could be useful too.
